Results 51 to 54 of 54
Thread: bq's Ciclop 3D Scanner
03-08-2016, 08:59 PM #51
- New York
- 66
03-16-2016, 07:23 PM #52
- Mar 2016
Hi there,
I can't get my ciclop to scan. I am having trouble with the auto check and calibration.
I get these error messages. I am using horus software.
Auto check - Check Motor Direction and Pattern Position and try Again.
Calibration - Laser Calibration failed. Please try again.
I am using Ardruino Uno and Zum Scan Boards.
I will be thankful for your help.
Regards,
waqz36
04-18-2016, 01:46 AM #53
- Jul 2014
- UK
- 124
Well, I gave up on the Cyclop and sold it. I just couldn't get a decent scan from it, no matter what I tried.
I've tried a few laser scanners and none of them produced results I would consider useable.
I now have an Einscan-s which uses structured light scanning, the difference in scan quality and speed is spectacular !
Admittedly, it's quite a bit more expensive but worth it for the ease of use and incredible scan detail, imo.Last edited by scobo; 04-18-2016 at 02:15 AM.
05-06-2016, 08:45 AM #54
- May 2016
Hi, I'm hoping to build the BQ Ciclop scanner and have a logitech C920 camera that I could use instead of the C270. I realise that the stl file holding the camera will need to be modified. But I have a few other questions;
1) Why is it necessary to remove the lense cover of the camera? Does the lense cover have a distorting effect on the lasers or is the cover only removed on the C270 so that the camera manual focus may be adjusted?
2) Is the lense center height in the plastic housing a critical dimension?
Thanks in advance.
