Results 1,001 to 1,010 of 4110
04-15-2016, 09:31 PM #1001
- Aug 2014
- 627
I put mine in 13 hours ago exactly so we will see but at least they just got in as it is morning time in China right now.
Off the topic at hand but I just noticed this forum's time is off by 7 minutes roughly (it is slow) because all of my clocks, and my internet time, said 38 past the hour and this forum said 31.
04-16-2016, 01:27 AM #1002
My printer arrived from China in 3 days from the order which was really impressive and allowed me to setup a week earlier than planned!
I shared the first round of basic parts I designed for my printer on thingiverse. The wire covers are pretty cool to accent your printer IMO and hopefully they print properly for others.
Interior Square Corner Wire Hide Covers
Interior Heated Bed Wire Hide Cover
Acrylic Printer Cover Filament Guide / Acrylic Straightener
04-16-2016, 03:50 AM #1003
- Mar 2016
- 29
04-16-2016, 06:24 AM #1004
- Mar 2016
- 29
Just a quick question
I want to print the cable chain but i am not sure what parts i need to print as there are two drive mounts and some other different things
Should i just print the lot and see what i need or can some one please tell me witch parts i need to print
http://www.thingiverse.com/thing:124700
04-16-2016, 06:54 AM #1005
cablechaindrive_small.stl
chain_start.stl
~16 x cable_chainunit.stl
chain_start may need to be sanded to fit properly against the front wall - a picture of the one I just put together with 16 links can be seen here and may help - http://www.thingiverse.com/make:212517
04-16-2016, 07:59 AM #1006
- Mar 2016
- 45
Thanks, I realized what was wrong. It only shows you status information of the print if you print via Octoprint. If you print directly from the SD card on the machine, which was what I was doing, it will not show any print job info. I tried printing using octoprint for a couple of prints and it turned out pretty well. I am looking to add a webcam next.
Thanks again.
04-16-2016, 09:39 AM #1007
04-16-2016, 10:11 AM #1008
- Feb 2016
- 360
04-16-2016, 10:55 AM #1009
Could be soon. I have one right now if you want to be an early adopter. :-) $140 + shipping if you can print the plastic, $160 if you want me to print the plastic kit. Plastic kit includes top and bottom mount, Bearing nut retainers, 3 thumb screws with nylock nuts and spring retainers with silicon vibration dampers.
04-16-2016, 02:25 PM #1010
- Aug 2014
- 627
I have a question for the people who own this printer as it has been in the back of my mind for a while now but with two nozzles, effectors, motors, isn't all of that weight bad? I would hardly do much with the second nozzle but having it for when I would want to is nice. Since X has 140oz for just the two motors alone what is the fastest you can print with this machine before all of that weight slaps you hard?
140oz plus has to have sag on X and something QIDI uses on their machine writeup material is that 8mm harden imported rods is better than 10mm domestic rods (basically they are saying that Chinese made 10mm rods used on I guess the Creator Pro is inferior to their 8mm hardened rods) "Imported 8MM axis, hardness obviously higher than domestic 10MM. "
New member with print issue
