Results 731 to 740 of 757
02-29-2016, 08:28 PM #731
- Aug 2014
- 627
03-01-2016, 05:40 AM #732
03-01-2016, 07:26 AM #733
- Mar 2016
- Stockholm
- 13
I used this https://3dprinterchat.com/2016/02/3d...g-a-must-have/ what is the pros n cons compared to your version?
03-01-2016, 01:40 PM #734
- Aug 2014
- 627
03-01-2016, 10:12 PM #735
03-02-2016, 02:47 AM #736
04-10-2016, 12:02 PM #737
- Aug 2014
- 627
Any word? I have a printer that this is needed as I have not been able to print on it no matter what I try. The heavens refuse me as every single time I buy something to replace the print bed it comes warped as well. Either from the manufacturer or via shipping. I give up and I really do like 3d printing but this is beyond torture of 2 years and can't get the bed right. Only hope is a matrix leveling scheme I think.
04-10-2016, 01:14 PM #738
I added just that kind of thing like a year ago, and it is in the Release Candidate now so it's on its way
It's called Mesh instead of Matrix (ABL already has a "grid" method that I guess fools people to think it does more than it actually do)
From the original Pull Request https://github.com/MarlinFirmware/Marlin/pull/1619
And as mentioned earlier Roxy is working on adding an Automatic feature for it. Though, I did add a simple auto thing for myself http://www.thingiverse.com/thing:1120142
But I am very happy to see other testing it and liking it.
https://www.youtube.com/watch?v=FPO3CbrVMi4
04-10-2016, 02:01 PM #739
- Aug 2014
- 627
Well, I haven't used ABL in a long time since it only worked for a dead flat bed it was worthless to me since my problem has always been bent/warped beds. I thought I had it as I used Gino pads as a sort of wedge on the bad corners but nope. Just too far gone and the last replacement MK2B I purchased I had to send back and get a refund because it was warped too.
04-11-2016, 02:17 PM #740
- Apr 2016
ABL Help
I just built a GMax printer and the auto bed leveling is not compensating for the bed enough as it isn't the most level bed ever... I am using an MKS Base V1.4 with a BLTouch sensor and Marlin RC5 firmware. The whole process works and I can see the z-axis adjusting but it is not adjusting a significant enough amount for the nozzle to stay a consistent distance from the bed. Right now I am using the grid and 4 probe points in marlin (so 16 points recorded). Is there a way I can get the auto bed leveling to more closely follow the curvature of the bed? I am eventually going to upgrade to glass (have acrylic now) to get a more level surface but I should have to given that I have ABL and a fairly accurate sensor. Will just typing G29 V 4 into my start g-code make it work or will I need to do more?
