Results 11 to 16 of 16
04-01-2016, 10:42 AM #11
If you're getting dodgy readings when the bed is cold then I think a sensor replacement is in order.
04-07-2016, 11:20 AM #12
- Mar 2016
- central europe
- 8
Just reporting: I replaced the thermistor on the heated bed, my temperature reading is now much more accurate and within the expected 5%.
04-07-2016, 05:30 PM #13
- Jan 2016
- 26
04-08-2016, 09:19 AM #14
- Mar 2016
- central europe
- 8
I used this one: Cantherm MF58104F3950, got mine from ebay but digikey should have them too.
Digi-Key Part Number 317-1380-ND
Resistance in Ohms @ 25°C 100k
B25/50 3950K
Operating Temperature -55°C ~ 200°C
Mounting Type Through Hole
Package / Case Bead, Glass
The original was at 64kOhm while the new one was at 110kOhm. I took the readings on the fly, that's far away from a trustworthy measurement - but shows for me that the original one is clearly the wrong part.Last edited by noa; 04-08-2016 at 09:30 AM.
04-09-2016, 07:14 AM #15
- Apr 2016
- 10
If it helps anyone, I wrote up what I did to mine, and why, at http://www.thingiverse.com/thing:1403267
04-09-2016, 03:28 PM #16
- Jan 2016
- 26
Awesome.. thanks for letting us know.. I'll get ordering a thermistor and replacing mine..
I wonder why they did that.. Hard to believe it's an oversight.. I wonder if it was an easy way to ensure no one was having the bed too hot?
