Results 1 to 10 of 40
Thread: Problems with PetG
04-03-2016, 06:30 AM #1
- Apr 2016
- 10
Problems with PetG
Hi all,
I have tried to print with PETG the other day and it was a complete fail. PLA works just fine but PETG has those spider webs and the quality of the print is poor, even tho' all settings are the same besides temp. I use 0.2mm layers, 240C and 60C for the bed. You guys have any idea why it makes those spider webs? I assume the PETG is too runny at 240C?
Thanks in advance for your help!
04-03-2016, 06:31 AM #2
- Apr 2016
- 10
Also do you see the difference in colour....it seems to change the shade of blue for some reason too?!
04-03-2016, 08:40 AM #3
Mayeb try slow down your printing, PETG on my printer needs to print rediculously slow, like 30ms feed rate :/ otherwise it gets lots of little air bubbles in it and goes stringy too.
04-03-2016, 11:10 AM #4
- Sep 2014
- Brummen, Netherlands
- 265
I think you should dry your PETG filament. It has a tendency to absorb a lot of water, which results in stream bubbles and also an increase in stringing.
04-03-2016, 11:57 AM #5
Hi,
230° is enough.
Print perimeters outside-in.
I have absolut no problems with stringing !
PETG is a much better material than PLA.
I only use PETG.
PETG does not absorb water !
I print PETG at 160mm/sec.
No need to slowdown the print.
High quality prints at 80mm/sec:
lizzard.jpgLast edited by NitroXpress; 04-03-2016 at 12:18 PM.
04-03-2016, 01:10 PM #6
Try adding retraction. PETG is stringy stuff.
04-03-2016, 03:11 PM #7
- Sep 2014
- 265
04-03-2016, 08:36 PM #8Hex3D - 3D Printing and Design http://www.hex3d.com
04-05-2016, 06:46 AM #9
- Sep 2014
- 265
I received a sample of the Formfutura Bronze PETG last Thursday and immediately tried it out the same day. When priming the extruder I noticed that the extruded filament (Flashforge Creator Dual, 225 C nozzle temperature, extruded using the display load filament feature) was very rough, indicating a LOT of absorbed water.
I vacuum dried the sample at 50 mbar / 70 Celsius for over 6 hours to get rid of the water. Today I repeated the extrusion, and made a comparison picture of the extruded filament of last Thursday (I save a bit) and today.
As can be seen, the sample as it arrived gave enormous amount of steam bubbles (bottom). After vacuum drying it is now extruded perfectly smooth (top).
Shame on Formfutura for sending out poor samples.
04-05-2016, 08:33 AM #10
- Jan 2015
- 445
nitro.. would you post your retraction settings?
I use PETG almost exclusively, but i dont have it perfect yet. I have a blob once in a while, but im 95% of the way there.
thanks
