Results 91 to 100 of 107
02-13-2016, 02:37 PM #91
- Jun 2015
FFCP Noob here...is the FFCP 2015 version/model affected as well by the dragging problem? I printed a large bathtub model a week ago and it came out pretty ok me thinks:
02-23-2016, 07:14 AM #92
Any info about how to troubleshoot the head height difference with the new FFCP?
02-23-2016, 07:41 PM #93
- Feb 2015
- 91
For the last little adjustment, it is waaay easier to use a shim between the cooling bar and the carriage than to mess with the set screw and the heatbreak tube.
02-26-2016, 03:35 AM #94
- Aug 2015
- 21
02-27-2016, 12:53 AM #95
- Feb 2015
- 91
Rich Webb posted a pretty diagram here: https://groups.google.com/d/msg/flas...4/c9IABy6eBQAJ
However, when you get there be sure to expand the message, Google hid the image below the fold. You do this my clicking on the little dashed message below his post.
02-27-2016, 12:55 AM #96
- Feb 2015
- 91
By the way, I prefer to use thick silicon baking mat cut down to fit. I put one on both sides so I can adjust the height by compressing the silicon more or less by tightening the bolts.
02-27-2016, 04:28 PM #97
- Aug 2015
- 21
The mats sound like a pretty good idea to adjust on the fly if needed for whatever reason. Does it introduce any additional slop into the machine though by having a pliable material in there?
i know it seems contradictory, but I wonder if very thin sheets of silicon matting in properly placed sections could act as dampeners and reduce things like corner ringing or if it would make it worse..... Hmmm..
02-27-2016, 04:43 PM #98
- Feb 2015
- 91
04-03-2016, 05:17 PM #99
- Apr 2016
Still selling your setup?
- Are you still selling the setup for adjustment on the dual extruders for the FF creator pro?
- Do you recommend the smaller filament ptfe and why?
- Do you still use the same cooling setup for PLA or can you modify pretty much the same way with any of the mod's people have posted???
Thanks in advance!
04-04-2016, 04:42 AM #100
Hey there. Yep I have some in stock.
I do recommend the smaller PTFE tubing. It is more flexible and it allows you to load a new roll of filament without pausing since you can just push a new filament roll right after the empty one. With the bigger tubing this is more difficult since the filaments will pass each other in the tubing. The PTFE is translucent also so you can see where the filament is in the tubing.
I don't run any PLA, but the big frog looking PLA fan setup clips into the front of the carriage just like normal.
New member with print issue
