Results 1 to 10 of 48
Thread: Nightmare start
03-31-2016, 06:03 PM #39
- Jan 2016
- 26
It's about 0.2mm bigger in diameter. The spring extruders didn't actually come with gears.. The brass ones I have came with two other spring extruders which didn't fit.
I've taken the nozzle off again now and cleaned the nozzle out with a small drill bit.. A quick test on the filament load program for 30 seconds hasn't clicked yet but I will try again tomorrow to see how it is.. a little late for 3d printer noise here unfortunately..
EDIT: It fits tightly when no filament yes.. however I didn't check to see what it was like when filament was loaded.. I had put the fan back on by then.. Can do tomorrow..Last edited by d43d; 03-31-2016 at 06:10 PM.
