Do you have your EEPROM turned on. If so, it sounds like you are getting some bad values and should clear it (set it to the default firmware settings).
I do have EEPROM enabled. I'm using Clough's firmware from his website, which had it enabled by default.
By resetting it, do you mean running an M502? When I do that, and try running G28 and G29 again, I get the same result
