03-20-2016, 08:19 AM #1
- Mar 2016
- 10
Just bought a Wanhao Duplicator V1-Any tips/pointers?
Hi all,
New to the forum and 3D printing. Just bought a secondhand Wanhao V1. Setting it up now, and using the Wiki page for instructions. Does anyone have any other tips/things to check etc? Hopefully will get a print done later and show it on here.
Cheers,
Matt
03-20-2016, 05:09 PM #2
- Mar 2016
- 10
OK, quick question time...
The upper x rail - should this be bolted in? Mine is loose and can be pulled out of the holes in the frame. Is there a grub screw on this rail-like the one below it. If there is-is there a way to access it other than take the frame to pieces?
03-21-2016, 12:54 AM #3
Hi matt, I don't own one of these but have built a Prusa before, and no nothing should be loose at all. Nothing should wobble in a 3D printer at all, not motors, not carriages, not belts etc.. everything should be pretty tight.
If you have that grey metal one, I can't imagine you need to do too much, I did see somewhere they are shipped without the carriage attached, did you have to put yours on when you bought it?Hex3D - 3D Printing and Design http://www.hex3d.com
03-21-2016, 03:36 AM #4
- Mar 2016
- 10
Cheers Geoff. Sorted it eventually, both rods have grub screws but the top rail screw are an absolute sod to see, access and adjust. Think I may raise it with winhao. The next model just needs a few holes drilling in frame so that you can do this easily. Printed a cookie cutter and all seems good. I had a few issues getting print to stick to bed initially. But printer came with some print bed spray and this worked. I think this spray is just re-badged hairspray, smells exactly the same!
