Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Super Moderator DrLuigi's Avatar
    Oct 2013
    Location
    Belgium
    Quote Originally Posted by klack View Post
    ok so after some trouble shooting Colin has been helping me with... i switched the x and y drivers.. and then the skipping switched to the x axis... then i switch the now X driver with the Z axis and im no longer having the skipping issue im printing the full cube right now and it seems to be doing pretty well... ill post a pic of it as son as it is done. Though my extruder keeps getting stuck, the gear stops moving and i need to give it a little nudge every once in a while. hopefully i can get this all sorted out soon! seems like its getting there. thanks for the help guys!
    Like i already told you, its probably one of the POTs thats giving to low voltage,
    Use a multimeter and a screwdriver to adjust it, and get it around 0.389-0.4 (It should be 0.39)
    Just do that for all the drivers, as thats the most healthy for your motors
  2. #12
    Staff Engineer old man emu's Avatar
    Oct 2013
    Location
    Narellan, New South Wales, Australia
    DrLuigi,
    Where do you put your multimeter probes to get the stepper driver output voltage?
    OME
  3. #13
  4. #14
    Quote Originally Posted by beerdart View Post
    What filament and hot-end are you using?
    I am using a .5 jhead and this filament is abs from makersfarm
  5. #15
    Oct 2013
    Location
    Belgium
    I would highly suggest to take a look at those stepper drivers,
    As they can be a bit to much/to low.
    Doing this without a multimeter is quiet bad imo,
    I noticed that even the slightest turn can make 0.4-5 diffrence easily without you knowing it,
    And i had skipping when i was at 0.37.
    Might test later on today on a dry run if it would happen again or not.
    Probably i will just keep it at Z1 and repeat x50 y50 x150 y50 and make quick squares, So i can see if it has skipped.
