Results 1 to 10 of 4110
03-12-2016, 01:16 PM #10
I would expect more layer over layer registration issues with the z axis having lateral flex like that. The thing is you probably wont notice it until you are in the middle of the Z travel. Items over 50 - 60mm tall should show the effects. Then as the build plate gets closer to the bottom they would go away somewhat.
