Results 501 to 510 of 4110
03-10-2016, 04:08 PM #501
You may be able to use one of these for the voltage reduction.
http://www.amazon.com/Solu-Regulator...5%3A2470955011
03-10-2016, 06:26 PM #502
- Feb 2016
- 96
Yeah that does not seem trivial.
03-10-2016, 08:36 PM #503
- Mar 2016
piece of cake! lol.
03-10-2016, 08:52 PM #504
Here are some pictures of the drag chain I printed for the X axis cables on my machines.
03-10-2016, 10:16 PM #505
Replaced the cable and I'm up and running again. Going to start printing the chain parts tomorrow.
03-11-2016, 11:37 AM #506
- Feb 2016
- 96
Oh interesting. I guess it didn't click that the chain cable has you re-route the cable down to the board directly instead of running up then along the upper right edge, then down the side edge, then down. Makes sense looking at it all of course.
Can you take a picture of how it attaches to your case on the end opposite the endstop and motor? From Thingiverse it looks like you have to drill and screw a few inches up the side. But on yours, I can't tell how it ends.
03-11-2016, 03:01 PM #507
On the Qidi I used an existing hole about 1/4 of the way up for the mount. On the CTC I drilled a hole lower since it's plywood. I like how the chain on the CTC lays and think I may drill a hole lower in the QIDI so it lays the same. The CTC mount is nearly as low as you can go just above the bottom deck.
Ideally if you read the older clone forums the ideal X axis cable routing is coming out the right rear corner of the machine. This is so you can move in RF generating cables away from the display. To help minimize the RF scramble of the display. As you can see I didn't do that.
03-11-2016, 10:08 PM #508
03-11-2016, 10:36 PM #509
03-11-2016, 10:58 PM #510
- Feb 2016
- 11
Curious what the deficiencies are if you've used both... I've never got to see a FFCP up close. There are a bunch of places I could imagine improvements but specifics would be great. Maybe there's an opportunity to engineer these things with just a little bit of effort.
All that said, it's not a fantastic printer, but it does a good job for my purpose: quick prints of things I dream up in CAD. I put together a BOM and this thing seems to be ~$100 over the low quantity parts I pieced together. Great value for the money with lots of room for improvement.
