03-05-2016, 10:01 PM #1
Shapeways SVX Format Allows You to Turn Game Code Into 3D Printable Models
A JavDev Coding post explains that it isn't that difficult to convert game code into a 3D printable model. One route for accomplishing this is to use Shapeways SVX format, which converts 3D pixels (voxels) into 2D slices that can make up an STL file for 3D printing. You have to make some adjustments -- such as adding a base, managing distance between structures in the model, and dealing with loose shells -- but all in all, it is not as complex as it first sounds. Selecting the right game level code and familiarizing yourself with SVX formatting are your first steps to having your own 3D printed game code. Read more at 3DPrint.com: http://3dprint.com/121798/3d-printed-game-code/
