Results 21 to 30 of 69
Thread: New CTC printer came broken
03-01-2016, 08:02 AM #21
03-01-2016, 11:15 AM #22
- Mar 2016
- Stockholm
- 13
Im right now putting together a list of problems that might occur when buying from chinese vendors or ebay sellers.. I will publish it on https://3dprinterchat.com . Is it ok if I use your exempel to?
03-01-2016, 12:13 PM #23
- Feb 2016
- 57
03-01-2016, 12:22 PM #24
- Feb 2016
- 57
I don't see a subforum for QIDI TECHNOLOGY. Has anyone heard much about these?
http://www.amazon.com/TECHNOLOGY-Ext...dp/B00SB6ZO8S/
I just want to avoid the wooden frame if possible. My friend is so lucky because he got one of the regular CTC printers (bizer I I guess) with a metal frame instead of the wood.Last edited by dspdrew; 03-01-2016 at 11:32 PM.
03-02-2016, 06:14 PM #25
It hasn't earned sub forum status but we have pretty good thread going here.
http://3dprintboard.com/showthread.p...icator-2-clone
Qidi Techs while a clone is as near as I can till exactly the same as a Flashforge Creator Pro.
There support is top notch from China.
It can also be bought on Ebay for $660 shipped.Last edited by rcleav; 03-02-2016 at 07:56 PM.
03-02-2016, 07:28 PM #26
- May 2014
- 67
03-02-2016, 08:57 PM #27
- Dec 2015
- 80
Damn, you can actually buy the acrylic enclosure for a qidi on ebay for just £26!
Wish they sold one for the CTC for the same price!
03-02-2016, 09:18 PM #28
I also have a CTC and bought an enclosure kit from these guys. http://www.criticalmods.com/
It's cost more then Qidi but it's a lot better built.
Liked it so much I'm buying just the hood for my Qidi.
I will have to feed the filament from the top which is what I'm doing with the CTC.
03-03-2016, 03:02 PM #29
Enclosures can cause the X & Y Stepper-motors to Over-heat and Fail,
I recommend not using the enclosure and adding a Fan at motors.
There really needs to be good air-flow thru the printer,
since other components can get too hot also.
Note: Fan at motors is probably needed Only if Room-temp is High,
during Summer, in locations where temp gets high.
Just touching the motors will let you know if they are Too Hot or not.
Ours was getting Too hot to touch before adding the Fan and that was without an enclosure.Last edited by EagleSeven; 03-03-2016 at 03:11 PM.
03-03-2016, 04:42 PM #30
Fortunately or not mine is in the basement with temps between 60F and 68F.
It doesn't stick very well at those temps.
As you can see I do monitor the enclosure temp.
