Results 1 to 10 of 16
02-15-2016, 02:11 PM #4
- Jan 2016
- 26
Ah.. yes I wonder if it's a sensor error.. as a "quick fix" is there a way that I can set it to higher than 120 degrees? (which I'll measure with a probe to check real temperature) Whenever I set it to 140 with simplify3d, it shows up as 120 on the onboard LCD.. I'm still running the onboard firmware 7.2
