Thread: Marlin RC SD problem
02-12-2016, 01:51 PM #1
- Feb 2016
Hi
I just designed and printed a new piece to raise my Z axis to 11 inches on the i3 I have. I cannot get Marlin configured for the SD card reader. I something wrong? I have Marlin working in the old 2560 but it's set for the old 200mm height. Never had a problem compiling and running the old Marlin.
Thanks
02-12-2016, 02:21 PM #2
In the newer Marlin's the SD Card stuff has been broken out and is separate from the controller board. Are you sure you have the SD card turned on?
02-12-2016, 03:12 PM #3
- Feb 2016
I have the Full Graphic LCD. It always worked with the version I was using two years ago.
02-12-2016, 03:17 PM #4
- Feb 2016
How do I get the cool Marlin splash screen into the code? Thank you
02-12-2016, 03:41 PM #5
- Feb 2016
Found the SD card comment. It is now uncommented. I was starting to think I had gone stupid.
02-12-2016, 04:51 PM #6
- Feb 2016
Goes into hit endstop without moving. Uncommented the manual endstop. Inverted the switch logic and everything works. Really work good with the Simplify software. Thanks for your help.
08-01-2016, 01:34 PM #7
- Jul 2016
on my controller the sd card doesn't work either.
with my ramps i have the following problem --- when i want to move the X it works but when i want to move the Y the Y doesn't work but instead the X turns .... does anybody know how this is possible ?
thx
Moderator note: Post is late to appear due to unexpected delay in obtaining moderator approvalLast edited by printbus; 10-05-2016 at 06:59 PM.
