Results 11 to 20 of 20
Thread: HobbyKing printer
02-09-2016, 03:09 PM #11
Yes its a shame that there are some quality issues with their printers because without the issues the Mini Fabrikator would be outstanding!
We have a mini fabrikator which does work and works well (for the size/price) so if you're able to repair/replace parts yourself then the Mini Fab is a great option.
02-10-2016, 08:47 AM #12
02-10-2016, 09:35 AM #13
You mean the grub screw holding the aluminium pulley wheel to the motor? I can find out for you if you want? I have a feeling it requires a 0.9mm allen key but not sure
02-10-2016, 11:40 AM #14
Yep that is the one, and YES I would love to know the size. It's hard to order the correct hex key without the size I'm finding.
02-11-2016, 06:24 PM #15
For those keeping score, it appears the grub is .9mm hex.
02-11-2016, 09:07 PM #16
- Nov 2015
I just got the new 1.5 version and have been printing away after an initial hickup.
02-12-2016, 05:30 AM #17
Yes sorry for the delay,
Yes I can confirm it is a .9mm hex screw.
However, I have one of the first printers HobbyKing sold and HK are known for subtly changing parts in products.
02-12-2016, 08:50 AM #18
Would anyone using this printer with S3D be willing to share there configuration file?
While I was trying to fix the problems with mine, I discovered the Y axis grub not tight either. Ay Caramba!!
3dex Ltd: I can confirm that Mine (v1.5) is .9 (the tool kit I ordered had hex bits from .7 to 3mm)
02-12-2016, 11:06 AM #19
- Nov 2015
Chuck from youtube has a profile setting on his site. I haven't looked at it because I don't have s3d.
Elproducts.com/fabtikator-mini.html
02-12-2016, 11:39 AM #20
New member with print issue
