Thread: Automatically Hollow a 3D Model
02-10-2016, 04:04 AM #1
- Dec 2015
- 12
Check out how to automatically Hollow your 3D model.
Hollowing out a 3D Model is a re-mesh of the 3D model, emptying out the core, which will lead to less material waste, lower the cost of 3D Print, and saves print time.
https://youtu.be/6dlc4I25IlYLast edited by reemaj3D; 02-11-2016 at 02:16 AM.
02-10-2016, 06:03 AM #2
or you could simply just use 0% infill and accomplish the same thing without hassle :-)
02-10-2016, 06:55 AM #3
02-10-2016, 08:40 AM #4
02-10-2016, 04:16 PM #5
And I don't know about saving weight or material either. Walls are where most of the material/structure is, if you hollow out an object, you'll double the number of walls needed. Made a paint rack for testors paint bottles a while ago (http://www.thingiverse.com/thing:622033 if anybody cares, but it is that paint bottle rack that testors should have but never made). I made serious attempts to cut back on the material usage by hollowing it out. Turned out a hollow structure was using 10-15% more material than a "solid" one at 10% infill.
That's why with my racing boat parts, I don't add "drill holes" to save weight. The added walls actually adds weight vs leaving it honeycombed.
And while it's very dependent on the exact print, laying infill is vastly quicker than laying another wall.
02-11-2016, 02:24 AM #6
- Dec 2015
- 12
I am aware of that. This is mainly for powder material such as sandstone.
New member with print issue
