Results 121 to 130 of 4110
02-05-2016, 12:27 PM #121
Yes I do makes things so much easier with more control.
02-08-2016, 09:29 AM #122
- Jan 2016
- 81
Sorry for the delay, here is the picture of the two boards. I see no difference lol.
I am also adding the pictures of the replacement.
I have developed a nasty sound from the Y axis. I was told by support it is just because of pressure and that I can fix it by loosening the grub screws on the two pulley's in the back corners, moving it back and forward a bunch fastm then pulling it all the way forward and tightening them down again.... Not sure if it will work. Make sense to you? I'll add videos here shortly of the sounds... I think it is because the rod in the back is bent slightly as the sound comes and goes when it rolls to the 'down' bent position... And when you move it un-powered you can feel it is smooth, then has more resistance, then less, then more, then less, etc, all in timing with that rod turning to the bent down position.
02-08-2016, 09:32 AM #123
- Jan 2016
- 81
02-08-2016, 11:00 AM #124
02-08-2016, 11:07 AM #125
And those boards are different. at first glance one board is missing a connector and chip.
02-08-2016, 11:47 AM #126
- Jan 2016
- 81
02-08-2016, 11:49 AM #127
- Jan 2016
- 81
02-08-2016, 12:51 PM #128
02-08-2016, 02:07 PM #129
- Jan 2016
- 81
I am thinking about doing an upgrade to the Build Plate.
Going with the MagHold magnetic build plate... Looks pretty epic, and useful!
On a side note I had a bad motor driver out of the box on that new board lol. I couldn't get the extruder to work, it would just click back and forth and make grinding noise, but if I hooked it to the other extruder's plug it worked fine, so i swapped it out and it worked!!! On a plus when the new board I got 5 extra drivers! woohoo!
02-08-2016, 03:04 PM #130
Other then the Cutout connector which is not used they do look identical. You could use either board because the hardware seems the same. What might be different is the firmware version. But even with the older firmware the cooling fan was controllable when plugged into the 2nd from right plug. I've included a pic of my board with that plug circled in red. I had to actually add the green plug to my board as it was the one missing.
On my CTC which has the same board it had the green plug but was missing the little chip in front of the plug. I have since added that chip to it so it has a cooling fan now to.
