Results 1 to 10 of 10
02-03-2016, 10:28 AM #2
- Sep 2015
That sounds stange. I never use the raft feature, no matter of platstic, (ABS, PLA, Ninjaflex, Nylon, Pet).
If the temperature and print speed is the same for raft/no raft and the buildplate is level the only factor left I can think of is the 0 height calibration.
Do you subtract the thickness of the paper (0,1 mm for normal 80g/m^2 printer paper) after you have calibrated?
The raft layer often use a higher layer height and width to acceive a better adhesion to unlevel beds.
Could that be one factor?
