Results 1 to 10 of 38
Thread: Maximum Overhang?
02-01-2016, 11:52 AM #1
- Feb 2016
Maximum Overhang?
Hi,
now that the first printers are shipping out, I'd have the question if anyone figured out how much overhang can be printed with the peachyprinter?
It's not really urgent (didn't order yet, and I guess if I ordered now, I'd have to wait for another year ), but I'm curious.
Thanks a lot,
Lukas
02-01-2016, 01:57 PM #2
Unless I've got this the wrong way round. The peachy prints on the surface of a rising reservoir of water. so the print is supported and always enclosed by the water. I would imagine this would let you print almost out at right angles with out any problems.
And makes it way more versatile than standard resin machines that pull the model from the surface of the resin.
You can pretty much print anything you like with no supports. Can't do that on a formlabs printer :-)
Yeah I'm right :-)
<br>
02-01-2016, 09:26 PM #3
- Sep 2013
- 308
Thanks for the great question tinloaf and
the great answer from curious aardvark
Ill just add this... as its a great clip of the longest over hang print we ever did. the hole print is one big over hang! talked about here at 4:20
02-02-2016, 10:41 AM #4
- 52
Just curious, can it do an overhang that drops? I'm thinking of something like a small case r where the arm droops, so when the printer is printing, the first bit will not be attached to the it, until a few layers are made. If the printer isn't jostled can the two separate parts join up without a rough surface?
02-02-2016, 11:53 AM #5
Hey iplayfast,
I'm pretty sure, that won't be possible.
As the resin floats on the water, a created Island will also float and not stay at the same height with rising water.
Also although the printer doesn't exceed any force on the resin, wind, surface tension (or some jedi) could make the Island drift away.
Fortunately this also enables the PeachyPrinter to use really small support structures as there is virtually no weight to be supported.
Considering overhang, You probably can print full 90°, thats something to test for one of the guys that already have a printer!
I hope, this answers your questions.
Greetings,
quertz.
02-02-2016, 05:59 PM #6
- May 2014
- 17
Isn't the cured resin slightly more dense than salt water? if so any floating island would eventually sink when they get massive enough to overcome the surface tension of the water
02-03-2016, 06:28 AM #7
- 110
You probably can't print a "perfect" 90 degree overhang simply because of the mechanics of the Peachy printer - the water level is rising continuously (the printer has no control over that) and it's going to take time to print a large, flat plane. As a result, whichever bits get printed last will be higher. For accuracy, I suspect the goal will be to print a lot of layers, with minimal time spent on each one - so that the height change during each layer is kept as small as possible.
02-03-2016, 07:00 AM #8
- 46
Only to clearify this, you can't do it with the default dripper system. If you change the dripper into a controlled system, like a pump or something, than the peachy should be able to print a perfect 90° overhang.
02-03-2016, 09:24 AM #9
Umm you sure about that.
I understood the even on the original model the dripper was controlled.
Either that or the laser has to cover the entire surface of the print vessel for every single layer. Which would set a specific print time per layer that would allow any part of the surface to be printed.
Otherwise it would be impossible to print different things on each layer - the very definition of 3d printing.
Either way you can print the entire surface per layer.
And the resin must be less dense than the water otherwise the whole thing just would not work.
02-03-2016, 09:53 AM #10
Hey guys,
I'm pretty sure, Peachy's default dripper system is uncontrolled, at least not by electronics.
Using extreme numbers:
If the water takes 20min to rise 10cm (I guess, that's a fast, but realistic print), you get .5cm per minute and during those 10sec per Layer (see videos) the water will rise about 1mm per Layer.
The Platform being maybe 5cm wide, this gives you 88.5°.
Seems pretty close to 90° to me (As I said before, I think, these are really extreme numbers).
Making the dripper slower (I guess, .2cm per minute is a realistic value) you can get angles as close to 90° as you want.
Greetings,
quertz
New member with print issue
Yesterday, 08:57 AM in Tips, Tricks and Tech Help
