Results 11 to 13 of 13
01-28-2016, 06:05 AM #11
the epoxy just brushes on - no sanding or other faffing about required.
To be honest I don't know why people are so obsessed with buggering about with printed things. Mostly the finish is pretty good anyway.
01-28-2016, 07:01 AM #12
You could just use thinner layers.
01-28-2016, 07:48 AM #13
- Aug 2015
- Wisconsin USA
- 27
In fact, it works surprisingly well! I use a wood burning soldering iron that came with maybe a dozen or so tips that get screwed on. Once you dial in the right temperature, you can smooth, cut or weld pieces together. I've only worked with PLA though.
