01-25-2016, 03:11 AM #1
- Jan 2016
kapton dont stick in the plataform
Hello
I have an isue with the kapton, i recently bough one tuve of it and the first time i stick it in the blue plataform is great, butn abter the printing, onece the plataform gets cold, the kapton crumples and i have to stick it again. The thing is that in the second printing, the corners get peeled and it deforms mi print.
Does anyone have any advise or tip to solve this problem?
Thank you
01-25-2016, 07:25 AM #2
clean your printbed with acetone BEFORE applying the kapton tape.
It is - or should be - very sticky. Sounds like your printbed was not clean when you applied the kapton.
01-25-2016, 08:31 PM #3
I gave up on Kapton tape a long time ago. Seems now like it was a waste of time and money. I found better solutions.
01-26-2016, 07:36 AM #4
Yep, get a sheet of Glass, to go on bed, and use Aqua-net spray for adhesive.
(and use PLA filament, if not already)
