Results 1 to 10 of 4110
01-19-2016, 07:10 PM #11
- Jan 2016
My Qidi works fine in ReplicatorG.
But I run into problems with other SW that I downloded and tried.
When I export files from Makerbot Desktop version 3.8.11 , it will not set the extruder temp in the g-code. I've tried the Replicator Dual, the Replicator 2 and the Replicator 2x settings with the same result. I also tried to use the recognized Qidi-Printer setting when USB is connected, no dice. Anyone has a workaround for this, except manually setting the extruder-temp on the printer?
Lastly, has someone on this board a working Qidi calibration file for slic3r?
Any help woul be appreciated.
