Results 31 to 40 of 84
01-15-2016, 05:18 PM #31
Trying to set this up on a Marlin printer. I have the card configed And it shows up in the router but I can only connect via a computer that has WiFi is there anyway to connect to a wired home network computer?
Config
[Vendor]
CIPATH=/DCIM/100__TSB/FA000001.JPG
APPMODE=6
APPNETWORKKEY=********
VERSION=FA9CAW3AW3.00.00
CID=02544d535731364731d8b8607900f601
PRODUCT=FlashAir
VENDOR=TOSHIBA
MASTERCODE=xxxxxxx
APPSSID=flashair
LOCK=1
DNSMODE=1
BRGSSID=xxxxxxx
APPAUTOTIME=0
WEBDAV=2
TIMEZONE=-20
UPLOAD=1
UPDIR=/
01-16-2016, 01:02 AM #32
- Burnley, UK
- 1,662
APPMODE should be 5. Does your router really have an SSID of "flashair"
It's been a while since I did this so if it doesn't work after that then post back
01-16-2016, 08:17 AM #33
Ill try 5 but 6 is station mode with internet pass-thru. Yes my router shows SSID=flashair as the cards SSID is "flashair"
01-16-2016, 08:30 AM #34
- Burnley, UK
- 1,662
I really think it should be 5 but as I say it has been a while. I have posted the links on how to do it in the forum somewhere.
Are you using a Linux editor, a Windo$e one will not do.
Are you replacing the * with your network key before you save it.
01-16-2016, 09:15 AM #35
Im using notepad++ and yes im replacing the * with the real key. Just tried 5 and it wont connect to the router.
01-16-2016, 09:28 AM #36
- Burnley, UK
- 1,662
Is notepad ++ linux compatible?
It says here: https://notepad-plus-plus.org/ Windo$e only so the end of line will be CR/LF instead of just LF.
Look at the config file in a hex editor,see if it has two characters at the end of each line.
01-16-2016, 09:48 AM #37
01-16-2016, 10:04 AM #38
- Burnley, UK
- 1,662
I am not the person to ask about Windo$e, I never use it unless I am forced to.
Ultraedit will edit linux files under Wind$e.
01-16-2016, 10:49 AM #39
Do I have to Initialize first using the flashair tool? Or just edit the config?
01-16-2016, 10:51 AM #40
- Burnley, UK
- 1,662
I just edited the config on mine. I have never used any sort of Windo$e software on mine at all.
