Results 31 to 40 of 52
01-13-2016, 12:00 PM #31
01-13-2016, 12:10 PM #32
01-13-2016, 12:14 PM #33
01-13-2016, 12:43 PM #34
Yes I had adhesion problems when I used the black but this was curable with some low tack glue on my print bed. I had a few issues with the white as well.
Luckily don't have any such issues now that I use our own filament (3dex filament)
01-13-2016, 04:53 PM #35
Some people have talked about warping and how you need an enclosure for ABS. But if you don't have one as part of your printer, a regular cardboard box will do. Here's an image of the one in our office:
https://forums.pinshape.com/uploads/...cfa5459b04.jpg
It definitely looks a little silly, but that was before we had found a big enough cardboard box. It worked
We did have a guest blog a few months back for a guide on PLA vs ABS here. There's a handy summary chart at the bottom on the main characteristics that you may want to consider!
01-14-2016, 12:08 AM #36
01-14-2016, 03:13 AM #37
Yes nothing is silly if it works and serves a purpose. is the box merely to retain heat?
Luckily, I've not had any issues with warping when printing ABS
01-14-2016, 06:41 AM #38
01-14-2016, 08:27 AM #39
- 3D Printer Tellus
- 83
I found this article for you, ABS VS PLA -----all explained nuff said! You like it? Visit my sign, =)==)==)
01-30-2016, 07:52 PM #40
- Jan 2016
- 326
I bought two small spools of Makerbot PLA filament at Staples store. I thought that PLA is brittle but I think that Inland ABS filament is brittle. I drilled larger holes through objects made from PLA and they don't break. Objects made from ABS sometimes break if I put screws through them. Are there cheaper but good PLA filament?
