Results 1 to 10 of 12
Thread: Skipping layers?
01-12-2016, 07:49 AM #4
Have you checked the filament-extruder drive-Gear,
to see if it needs cleaning ?
(teeth of gear can get filled with plastic,
causing filament not to feed properly)
I use an Xacto-knife and small wire-brush to clean it.
Here's a video about how to do that:
(CTC is similar to FF, your extruder may not have the Arm type assembly)
http://www.bing.com/videos/search?q=...390&FORM=VIRE7
Note: we upgraded to the spring-loaded Arm type,
since it seems a little more reliable,
even though it is a little more difficult to assembleLast edited by EagleSeven; 01-12-2016 at 08:34 AM.
