Results 1 to 10 of 12
Thread: Skipping layers?
01-11-2016, 11:35 PM #1
- Oct 2015
Skipping layers?
Hey all! I have been printing on the CTC for a bit now, really love it, the print quality is great once you dial it in, but I have been having a strange issue on mostly taller prints, it seems that it 'skips' a layer every now and again, any ideas on what may cause that? I have tried slowing it down, but have seen this behavior as low as 30mm/s, have messed with temp settings and no luck either. Most of what I've read is it could be a filament tangle, speed, temperature, or z axis related, any thoughts? (the small jittery layers is what i mean)
01-12-2016, 07:15 AM #2
- Dec 2015
- 80
It's not skipping, that is due to shrinkage due to parts cooling faster than others I believe.
01-12-2016, 07:32 AM #3
- Oct 2015
No it's definitely skipping, I've watched it on those layers and it's like it's not putting them down, I can't decide if it's the z axis having an issue or if it's not extruding well in those areas though.
01-12-2016, 07:49 AM #4
Have you checked the filament-extruder drive-Gear,
to see if it needs cleaning ?
(teeth of gear can get filled with plastic,
causing filament not to feed properly)
I use an Xacto-knife and small wire-brush to clean it.
Here's a video about how to do that:
(CTC is similar to FF, your extruder may not have the Arm type assembly)
http://www.bing.com/videos/search?q=...390&FORM=VIRE7
Note: we upgraded to the spring-loaded Arm type,
since it seems a little more reliable,
even though it is a little more difficult to assembleLast edited by EagleSeven; 01-12-2016 at 08:34 AM.
01-12-2016, 02:13 PM #5
- Oct 2015
Just checked the gear on the extruder, seemed to be fine/clean. Did some other checks on it and still am kind of at a loss on it. I thought about upgrading to the spring loaded extruder block, which one did you use for yours?
Also it has randomly started randomly showing a bunch of jumbled mess on the LCD screen, not sure what's causing it, bad sailfish flash maybe? Its weird because I've printed on it probably a couple hundred hours now and it just started that!
01-12-2016, 02:40 PM #6
I found a Set of Arm type extruders on eBay, at low cost,
from a place in UK.
I can look for details of that order if you need them ?
Spikes on AC power line to printer can cause the display jumble problem.
Can be caused by an AC type Fan or other device with motors.
Moving power-cords, going to printer's power-supply or to other devices, away from printer Mobo, can help also.Last edited by EagleSeven; 01-12-2016 at 02:49 PM.
01-12-2016, 07:00 PM #7
- Dec 2015
- 80
You can also print them out, couple of prints out there
http://www.thingiverse.com/thing:231310
http://www.thingiverse.com/thing:42250
http://www.thingiverse.com/thing:53125
01-12-2016, 11:04 PM #8
- Oct 2015
I went ahead and grabbed one of the arm extruders off the bay, hopefully that'll help with feeding (which I suspect may partially be the issue). I went ahead and cleaned everything out while I had it apart earlier, going to do some oiling of the bars and all that and will give it a go tomorrow sometime!
01-13-2016, 07:45 AM #9
01-13-2016, 07:55 AM #10
Yes, I think putting a drop of oil on bars, often, really helps,
as long as you clean away the dust that collects at ends of bars, in the oil.
