Results 1 to 9 of 9
Thread: Replicator 2 Non-Stop Beeping
08-08-2015, 10:43 PM #1
- Aug 2015
Hello all,
In a bit of a pickle and am looking for anyone who might be able to give some incite.
All of a sudden, my Replicator 2 starts beeping a little "song" when it is powered on and will not stop. The arrow and M buttons are unresponsive.
But the weird part is I can still send a print over. During the printing process, the beeping stops. As soon as it is done, the beeping starts back up.
Anyone have any ideas as to what might be going on? Thanks in advance!
08-08-2015, 10:59 PM #2
- Burnley, UK
- 1,662
I suspect you have a stuck button.
08-08-2015, 11:23 PM #3
- Aug 2015
That was my thought as well. I took apart the front panel and the LCD/button area. Took off the rubber arrows to see if anything looked strange. All the sensors for the buttons looked fine. I then turned on the machine without the rubber arrows and got the same result. So my next thought is something on the button board might be fried.
08-12-2015, 02:03 AM #4
- Mar 2015
- Slovenia, Europe
- 76
Hi there
your printer has to be serviced. Look like there is problem with electronics.
I sow it before so I'm prety much sure you will not be able to work this out other way then with Makerbot service center.
Regards
Roberto
12-29-2015, 09:52 PM #5
- Dec 2015
My Replicator 2x just started doing the EXACT same thing. Wondering if you found a fix for the problem. Any guidance would be greatly appreciated.
01-04-2016, 04:14 PM #6
- Feb 2015
Did anybody figure out the solution to this? Mine just started doing the same thing yesterday!!! Grrrrrr
01-04-2016, 04:15 PM #7
- Feb 2015
I tried flashing the firmware to sailfish and the beeping stops but the LCD screen becomes unresponsive.
01-07-2016, 01:13 AM #8
- Mar 2015
- Slovenia, Europe
- 76
Hi there
look like you have PCB failrule. I don't see any other option.
You should take your REP to Makerbot service and they will fix that for you.
01-12-2016, 08:43 AM #9
- Jan 2016
Am having that issue myself. Called up makerbot and they're sending me a new front display unit. If you stick a blank card in the SD slot it will shut up but I am having the same problem. Will try to update next week when I get the new front display.
New member with print issue
