Thread: 3D scanner
01-04-2016, 03:37 AM #1
- Jan 2016
3D scanner
rojection technique non contact frequency conversion fringeFull Body Scanner Model# EDR_BC105S Field of View 700mmRx2150mm(H) 28"rx86"(H) Single Surface Accuracy <0.1mm Average Sampling Point Distance 0.7mm Light Source White Light Output Format wrl obj stl Image Resolution 1.3 Mega Pixel Texture RGB 24 digits Photographying Time 3 seconds-5 seconds Data Registration Automatic Calibration 3D Fiducial Mark Weight 720KG Dimension 400mm(L)x500mm(W)x2100mm(H) Power 4800W Power Voltage 220AC Interface Recommended Computer Configuration i7/8G Ram/Win7_x64 O.S. 3-Second finishing scan of the full body in 5 directions, and only 45 seconds to finish the data registration.
Projector (1280*800 WXGA; DLP)
Light intensity ANSI 3500 LM
Texture 24bit RGB
The minimum uptake time was 3 Minutes (scanning per 360 degrees)
Environmental light intensity compensation adjustment
Point cloud average point spacing 0.5-1mm
Single scanning accuracy of less than 0.05mm
Depth of not less than 1200mm
Shooting range maximum 250mm * 250mm * 100mm * 100mm * 100mm 240mm/ minimum
Output format STL, WRL, PLY, OBJ and other formats
Automatic mosaic of data
A scan integrity of the normal situation of more than 90%
Calibration method encoding logo point stereo target
Equipment weight 18.9 kg
Equipment power 220AC/198W
Connection mode Ethernet (Gigabit Network) connection
Operating system Windows7 64 Bit
Website: http://studio.3dplus.cn/en/index.php
Skype:c1111212432@163.com
Email: cheny@esdisplay.cn
Any
