Thread: Heat Bed terminal burn
01-01-2016, 11:07 AM #1
- Jan 2016
- 11
Hy guys, just got my electron 3d printer. At first my heat bed was working fine for some hours or so. After that i saw that the bed is not heating up. I checked the controller board and saw that the Heat Bed terminal is damaged. http://imgur.com/AjsWVfb http://imgur.com/f3tdKqR http://imgur.com/byG75be These are the pictures i took.
I would like to ask if somebody knows what could happen. Nothing else is damaged, the printer is working fine, only the heat bed not heats up. Another question is that is it possible to fix this if i swap the terminal to a new one?
Thanks.
