12-31-2015, 01:45 AM #1
- Dec 2015
Reptier host connects to 3D printer but doesn't print?!?!?
Hello the title pretty much explains it,
So all I can print is a cube off the sd card and I don't have a sd card reader so I can't put any files on that.
So I set the bruad rate correctly and all that, reptier host detects it and my computer but when I click print it says ETA and then printing but nothing happens
12-31-2015, 02:49 AM #2
- Burnley, UK
- 1,662
So buy a card reader or flashair card. You shouldn't print over USB anyway, you will end up wasting plastic because the USB fails.
12-31-2015, 07:29 AM #3
My guess is that the Slicer-software you are using is not compatible with the Firmware version in printer.
I've seen that happen.
Try Different Slicer-software !
USB is Best ! SD is too much trouble !
Our USB connection has Never failed !
(Of course you Need a Good Printer, cable, software and Computer to get that Good connection)Last edited by EagleSeven; 12-31-2015 at 07:39 AM.
