Results 1 to 10 of 11
Thread: Samsung Galaxy S4 Stand
12-28-2015, 07:05 AM #1
Finally got around to make a new stand for my cell phone. Designed with Geomagic Design, sliced with Makerware 2.4 and printed on a Flashforge Creator X.
Layer height: 0.1mm
Material: eSun silver ABS
Feed: 50 (25 perimeters)
Total print time: 17hrs
First, this is the part fresh off the printer:
12-28-2015, 07:07 AM #2
Here is the part after sanding:
12-28-2015, 07:09 AM #3
And finally the finished part, spray painted matt black:
12-28-2015, 01:45 PM #4
I like it, turned out really nice!
Holy cow.. 17hrs....
Infill?
12-30-2015, 06:22 AM #5
12-31-2015, 08:03 AM #6
it's very pretty :-)
BUT - if you intended to paint and sand it all along - why print at 0.1 mm ? And why print so slow.
Should be able to knock that out in 2-3 hours I would think, and after sanding and painting would look identical.
But then I'd never sand or paint stuff anyway. :-)
01-03-2016, 02:16 PM #7
I didn't plan to paint it. Was hoping to leave it in silver but I wasn't quite happy with the roof finish in one area so I wanted to fix it.
I don't believe in pushing machines to run flat out. So I run my printer slow. As a general rule: outer perimeter and first layer 25, all the rest at 50. Rapid is set at 80. Gives consistently good results.
01-04-2016, 01:56 AM #8
01-14-2016, 03:13 AM #9
UPDATE:
This is design in such a way the whole model is parameter controlled. Since I print these quite regularly for all sorts of people I simply change the parameters for phone width and thickness and the model updates (for those not familiar with CAD practices).
Last night I started printing two new ones for the S5 mini. This time I upped the feeds...
was: outer shell = 25, rest = 50
now: outershell = 40, rest 60.
The result is quite impressive. All the issues I had with my silver ABS are gone. Got an amazing finish.
01-14-2016, 07:09 AM #10
still at 0.1 layer ?
I don't print that fast. normal for most pla would be 60mm/s s3d tends to sort the rest out and it never actually prints at 60mm/s.
For flexible filaments I tend to knock it down to around 40.
Layer wise 0.2 is the highest resolution I use. 90% of things get printed at 0.3.
Occasionally if I've got a big thing I'll print it at 0.4 - and just ignore s3d's wingeing about things not being in proportion - or whatever it says. Works just fine :-)
I'm definitely speed over finish :-)Last edited by curious aardvark; 01-14-2016 at 07:15 AM.
