Results 1 to 10 of 26
12-26-2015, 11:19 PM #1
- Dec 2015
- 22
new printer, made a few prints one messed up bad. Trying to learn, some questions...
Question 1:
So i got a new qidi tech printer and did the test cube from ReplicatorG and a few other things. They printed pretty well, examples that did great were:
http://www.thingiverse.com/thing:350055
http://www.thingiverse.com/thing:570039
and this one (Brick Rev ver2)
http://www.thingiverse.com/thing:26979/#files
All did fine...
This one failed bad:
http://www.thingiverse.com/thing:179150
(attached pic).
My question is what settings should I tweak or try, or maybe what did I do wrong to get it to come out all jacked up after the thumb part? Was it a setting? I used PLA and a heat setting I am guessing was too hot. It does have a heated bed too and I used recomendations made in the systems user manual. The gcode settings were this:
Object infill %10
Layer height .2
Number of shells 1
Feedrate mm/s 80
Travel feedrate 100
Print temp 220
(I am guessing the temp was too hot but no idea).
Oh use raft/support was on. None for support material. Use default start/end gcode and use print-o-matic was checked. Not sure if any of this helps, I used the settings for all things actuallly which brings me to my second question:
Question 2:
Is there anyway to mitigate the 'gaps' in a flat surface? (attached picture gaps circled).
Finally question 3:
What is the general finishing technique people use and tools? I know the support on the bottom can be peeled broken off but its still not flat? Sanding?
What paints are best? Primer? If going to paint pla model, what color filament is best as base?
Sorry for so many questions but I am excited to start to learn just not sure where to start looking, figured the forum here.
