12-15-2015, 04:49 AM #1
- Dec 2015
- Charlotte NC
- 11
Extruders won't Adjust up and down
I have a PowerSpec 3d Pro (Flashforge Creator Pro) and I'm having a horrid time adjusting my extruders, they are not level, and I understand the procedure for leveling, however, when I remove the set screws, the nozzles will not go up and down without turning them back and forth. It seems others can just nudge their extruders in place to go up or down. I'm wondering if others have had this issue and how they solved it.
J
12-15-2015, 05:21 AM #2
12-15-2015, 05:59 AM #3
Easiest way to solve this is to measure/gauge the difference in height between the two and raise the lower one using shim.
12-15-2015, 06:04 AM #4
- Dec 2015
- Charlotte NC
- 11
Yeah, I have some parchment paper (silicon infused paper) which is high temperature capable I've thought as using a shim, a washer on one side was too much. I've ordered some pullers from Amazon as well, I'm thinking I could use a windshield wiper puller or a simple gear puller to nudge the extruders in place. If the gear pullers work well, I'll post pictures.
Thanks!
12-15-2015, 06:36 AM #5
Not sure what your method is +
Just loosen the two screws under the heat spreader bar and place the shim between the bar and the carriage, Retighten the screws.
12-15-2015, 07:39 AM #6
- Dec 2015
- Charlotte NC
- 11
