Results 1 to 10 of 32
Thread: R.I.P. Power Supply
12-08-2015, 09:26 PM #1
- Aug 2015
- Vail, CO, USA
- 36
R.I.P. Power Supply
As you can assume from the title my power supply is deceased (or so i think)
All the sudden when I plug the ps cord in it doesn't turn on
I can't really think of anything that would cause this, all connections look good, extension cord works by itself
I think I would have noticed if the ps died from excessive load, and the last print i did worked all the way to the end
Does anyone have ideas about things i should check, etc.
12-08-2015, 09:35 PM #2
12-08-2015, 10:05 PM #3
12-09-2015, 10:31 AM #4
- Aug 2015
- Vail, CO, USA
- 36
Still under warranty?
I would check the fuse?
Thanks for the fast replies
12-09-2015, 11:07 AM #5
- Jul 2014
- 305
Has your power supply been making any weird noises before this?
12-10-2015, 04:02 AM #6
I assume you're using one of the usual 12V 30-amps or so switching power supplies that fit the mounting hole pattern on the MakerFarm printers. The vast majority of such power supplies sold on Amazon, eBay, and 3D-printer sites are low-cost knock-offs of a Mean-Well brand power supply. Presumably built with lower quality components or inadequate quality control, a few threads here have unfortunately discussed these knock-off power supplies failing.
While some failures might be caused by something simple like a bad solder joint that could be easily fixed, it's probably best to consider the power supply non-repairable. The original Mean Well design does have a replaceable small glass tube fuse (under the cover, on the circuit board near the terminal block) on the AC input but that would most likely burn open only as a precaution when something else has failed in the power supply. Any problem downstream from the power supply should just shut down the output, not open the fuse on the AC input. You could check it and replace it if it appears burned open or tests as open with a meter. If the fuse is good or burns open again after replacement, I'd look for a new power supply.Last edited by printbus; 12-10-2015 at 11:33 AM. Reason: readability
12-10-2015, 11:01 AM #7
Every power supply must have some kind of fuse for protection. Whether its internal or external. If you open it up I'm sure you could find a fuse. Open the power supply and send a picture here on the forum and we can help identify it for you.
12-10-2015, 09:12 PM #8
- Aug 2015
- Vail, CO, USA
- 36
Let me know if anything is amiss.
P.S. Yes the fuse is completely intact if you can't tell from the tiny picLast edited by spaceorange12; 12-10-2015 at 09:13 PM. Reason: Clarification
12-11-2015, 03:24 AM #9
- Burnley, UK
- 1,662
If the fuse is OK then it should be an easy fix. Have you checked the temperature sensor for continuity, the one stuffed into the green inductor?
12-11-2015, 07:16 AM #10
I lucked into a used power supply, so I don't have a vetted source to offer. Someone else might. Meanwell doesn't appear to be publishing any "how to identify a fake Meanwell" info, so I can't offer that either.
There have been a few threads where options have been discussed. Some have done well with the low cost knockoffs - you just have to accept the YMMV factor. Your range of replacement options depends on whether you want the power supply to mount on the printer frame. If not, some have used an ATX-type power supply. This thread mentions a server power supply that has been adapted for free-standing use - http://3dprintboard.com/showthread.p...nt-Requirement.
40 amps would put you into a 500 watt or larger power supply. Just as another option, MakerFarm at least used to suggest using two power supplies on the larger printers, with one dedicated to the large heat bed on those printers. A smaller one can be used to power the electronics, motor, and extruder heater.
