Results 11 to 13 of 13
Thread: Light sport aircraft 3d printing
12-08-2015, 03:41 AM #11
12-08-2015, 05:52 AM #12
thr guys who printed the sportscar with the BAM machine could do it.
I believe that other leisure craft apart from cars are on their todo list. small aircraft among them.
12-08-2015, 07:12 AM #13
As the OP seems interested in the ULM (ultra light motorized), the requirements from FAA or EASA are pretty much limited to :
- you have an altimeter ? Yes
- you have an engine ? Yes, and it works too !
- Then you're good to go, safe flight !
Pro : attractive low regulation environment.
Con : easy to kill yourself.
Sure, as far as ULM are concerned, anyone can do anything. I wouldn't mind trying a car, but an aircraft is something else entirely. I'd like to point out that for instance, a helo certification includes proving that the flight control system fail at over 500% the max effort necessary to control the machine in the worst configuration. Plastic is not appropriate for that. How would you feel about a broken control stick between your legs ? EDIT : ok that's not a good way to phrase it. Point is still valid though.
