Thread: Creator Pro simplify3D settings
12-03-2015, 08:35 AM #1
- Dec 2015
- 11
Anyone want to share their Simplify3D FFF process?
It looks like i'm under extruding when printing in PLA.
I'm using the default setting for the creator pro in simplify.
One thing that surprised me was the extrusion multiplier is set at 0.90. Wondering if it should be at 1.00.
12-03-2015, 11:50 AM #2
0.9 is normal. make sure you've measured your extrusion width and set that correctly as well. .
12-03-2015, 12:45 PM #3
My 2015 FFCP uses 1.0. I started at .9 and moved up in .2 steps until I settled on 1.0.
12-03-2015, 02:21 PM #4
Mine's set at .9 but I might try doing what ServiceXP said he did.
12-03-2015, 04:10 PM #5
I gotta say, you must use good calibers to measure that calibration cube, because visually I could NOT see any difference between my .90 and 1.0 cubes. Sebastian Finke turned me on to this guide. It was very helpful.
12-03-2015, 04:20 PM #6
- Dec 2015
- 11
Thanks guys. I thought it was odd to be at 0.90. I'll crank it up to 1.0 and check my prints.
10mm test cube time
12-03-2015, 04:43 PM #7
- Dec 2015
- 11
Yes. You must use digital calipers. Work like a charm.
