Results 1 to 10 of 18
11-30-2015, 01:40 PM #6
- Nov 2015
- 21
I'm not that familiar with much of the 3-D printing terminology yet, so I don't quite understand everything you said. I have created another design where I have indicated the thickness of the sections, just to make sure that we are talking about the same thing.
As far as shells and infills are concerned, is there a scaling principle involved based on the thickness of the material? For example, I read an explanation of shells and infills, and based on the example pictures of a cube measuring 1 cubic inch, three shells appeared to be only a millimeter thick. And a 25% infill appeared to have chambers/cells that were about 2 millimeters across. Now, I can understand using three shells for my design if the vertical thickness is 1.5 millimeter, but with 25% infill, I don't quite see how that would work. So that's why I was wondering if the size would be scaled down. Maybe I'm misunderstanding something.
