11-26-2015, 12:42 PM #1
SOLVED - G-Code lacking all the "G" extruder head movement commands ?
Using ReplicatorG-400
I have a small model that when I Generate the G-Code, has no lines containing "G" head movement commands?
(Well only 4 or 5)
It also says print time is less than one minute?
It's as if it completely ignores all the lines that tell the head where to move and how to move are omitted.
However, when the file is generated, everything looks and seems fine.
In the GCode cration report it says 39 minutes to build (which sound about right)
But that info differs greatly from the GCode I end up with in the viewer for unknown reasons.
After I generate the GCode, it opens two screens that contain what looks like an animation of the object and the toolpaths....
All I see the option to do is Save and Close"....am I supposed to be doing something else with those screens?
I don't understand that.
Anyone know why it might do that?Last edited by Ward; 11-26-2015 at 02:45 PM.
11-26-2015, 02:44 PM #2
Solved
RESOLVED
Boy THIS was an aggravating problem!
Under GCode --> GCode Generator
I had selected Version Skeinforge 50
Apparently THAT version simply would not work
I changed to Skeinforge 47 (the previous version) and VOILA ! All is good again.
