Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Quote Originally Posted by 3DMarkt View Post
    When you search a 3D Print who is cheap and just to try out first things, I can show you a good oportunity:
    The Wanhao Duplicator i3 costs 495 euro and works perfectly!
    Here the link:
    http://3dmarkt.at/en/3D-Printer/Wanh...D-Printer.html
    I'm prepared to pay for good results , cheap isn't important
  2. #12
    Jul 2014
    dependignon your budget you would probably benefit from a multi material printer like the hyrel.
    It can print in plastic, extruded clay and silicon and pretty much anything else that can be extruded.
    http://www.hyrel3d.com/
    And yep the easy part of the box is the squashed sphere. IN openscad it'd take a couple of lines of instructions to do that.
    Designed right you could actually print the hinges already in place.
    If you use a dual material printer you can simply print a join between the two halves with flexible filament.
    Printer wise - many many choices. Give us a rough budget and we'll give you a list :-)
    But none of it will be super fast to learn.
  3. #13
    "How easy is Cad to learn"? Unless you own CAD already, I would suggest a free version or even Sketchup to learn how to model. I have no training except for what I have learned on line with all the free tutorials out there and this would be easy to produce in one of the free versions.
  4. #14
    Jul 2014
    if you've never done any cad - then absolutely start with openscad. It's the only one where you'll have a printable object in 5 minutes.
    Most cad programs require a lot of farting about before you've got something you can actually print. Openscad ONLY makes printable objects.
    No drawing - you just tell it what you want and it makes it :-)
    http://www.openscad.org/
    The online manual was most likely written by some kind of idiot savant - it's basically gibberish and almost impossible to understan by a 'normal' person'.
    Fortunately there are lots of simple to follow tutorials online.
    http://edutechwiki.unige.ch/en/OpenS...l#Introduction
    http://blog.cubehero.com/2013/11/19/...s-in-openscad/
    My openscad tip of the day: when making spheres or cylinders use 'd=' to state the diameter rather than 'r=' forthe radius. saves you having to constantly have to calculate the final size of something from a radius - just state the actual size you want as a diameter :-)
    Why people still use r, I don't know.
    Or why people put the modules AFTER the actual model script. back to front to me.
    But I'm not a programmer :-)
    It probably all makes sense to whoever wrote the manual.
    Sketchup is a right bastard to make printable objects in. And - in my experience, the version you have is almost never the version in a tutorial so nothing ever works properly.
