Results 1 to 8 of 8
Thread: Odd Printing Question
11-25-2015, 10:37 AM #1
I have a FFCP clone.
It will only print up to 8.9" height x 5.7" width x 5.9" length
Unfortunately I would like to print something that is long and flat 6.5" long x 3.5" wide x .125 thick"
Since I obviously do not have the width needed, what would happen if I tried to print that object On EDGE ?
I'm assuming I would have warp city and it'd be about as wavy as the surf on a windy day.
Do I have no choice but to buy a 2nd 3D printer with a larger build volume to get that extra .6 inches?
11-25-2015, 11:00 AM #2
Split your article in two or more parts print and them separately. Then you can join then later.
11-25-2015, 11:28 AM #3
You can most certainly print it without cutting it. Just rotate it on the bed (something like 30°) I believe...
11-25-2015, 12:21 PM #4
Just rotate the object to fit the bed-space diagonally , in the slicer software, if it will fit that way ?
Go to this thread, to see what I did to solve those problems:
http://3dprintboard.com/showthread.p...ender-brackets
Our bed is now 11" long.
(There's a picture of the extenders in that thread but you must click the website's hidden-pages to see it ! ??? )Last edited by EagleSeven; 11-25-2015 at 01:23 PM.
11-25-2015, 10:40 PM #5
You can have it printed separately then assemble them afterwards.
11-26-2015, 12:42 AM #6
I know can improve the "config" file of print area/size in makerware file folder, and then just put a glass on top of the heat plate.
11-26-2015, 05:22 AM #7
- Sep 2014
- Brummen, Netherlands
- 265
The FFCP has a print bed of 8.9" width (X-direction) by 5.7" deep (Y-direction) and can print up to a height of 5.9" (Z-direction).
Your object fits perfectly on your printbed with room to spare in all directions????
11-26-2015, 06:02 AM #8
you've got the dimensions the wrong way round.
It's because americans always put numbers in the wrong order.
so it's actually 8.9 long by 6 wide by 6 high.
so: 6.5" long x 3.5" wide x .125 thick"
will fit on the bed without any problems.
My 3D Norn Emissary print
09-13-2024, 02:28 AM in 3D Printing Gallery
