Results 51 to 60 of 101
Thread: I need some serious help
10-31-2015, 01:32 PM #51
- Oct 2015
- Great Falls Montana
- 52
okay so i adjusted the horizontal offset and noticed that if i adjust the offset then move the the head to the defined area you gave me, it moves beyond the bed. so were y66 would stop at the edge , if i increase the horizontal offset it moves beyond the the edge. maybe that will help in figuring out what im doing wrong
11-02-2015, 10:12 AM #52
Now that you have the X0 Y0 Z0 nozzle height correct you just gotta get Diagonal Rod Length and Horizontal Rod Offset dialed in.
You're using Repetier-Host to make your eeprom changes right? Make changes 1-3mm at a time. Gross changes are good to show that you're making a difference (which it sounds like you are) but may damage your printer if you start going too far.
11-02-2015, 02:21 PM #53
- Oct 2015
- 52
Thanks , I'll mess with this tonight, then on to the extruder motor and calibrating it.
11-02-2015, 09:00 PM #54
- Oct 2015
- 52
okay now im getting excited , finally have this step working. one minor problem. z and y seem to be about the same as middle , but the x tower , the head moves up. how do i adjust just one tower?
11-02-2015, 09:17 PM #55
That's an endstop that's off. You need to either physically move your x endstop down or use a trimming screw if you have it.
I really hope you have trimming screws haha. Makes it a lot easier.
11-02-2015, 10:18 PM #56
- Oct 2015
- 52
i do have screws , but i did notice in the eeprom settings that i can set endstop offset, that work the same way ? and can you point me in the right direction for extruder calibration? i feel like im getting close to printing something
11-02-2015, 11:00 PM #57
- Oct 2015
- 52
i got it , its either dead on or off by .1 im pretty sure thats in tolerence so happy right now. going to bed lol. yea next on to the extruder motor calibration , and swapping the hotend..... THERE IS LIGHT AT THE END OF THE TUNNEL, I CAN SEE IT!
so how do i calibrate that there extruder motor again , and side note , what should i do about retract, saw you guys talking about that in previous post
11-02-2015, 11:07 PM #58
Yeah that should work the same same way. Give it a shot.
Extruder calibration has two factors.
1. Steps/mm. Usually called Esteps/mm. You can extrude 100mm and then measure it to see if it's 100mm. Increase Esteps if you're short or decrease if it's long. My sweet spot is usually a little less, like 80mm, but it varies. This is non melted plastic, before it goes into the hot end.
2. Retraction. Usually 2-5mm. Don't do too fast or accelerate too fast or you will strip the filament. Retraction settings can also be found in Slic3r or whatever slicing program you use.
11-02-2015, 11:23 PM #59
- Oct 2015
- 52
im not seeing esteps in the epprom setting on repiteir host , am i looking in the wrong spot or is it steps per mm ? for the extruder
and for the retraction , basically start small ... right ?
11-02-2015, 11:41 PM #60
It should be like "Extr1. steps per mm"
Retraction is pretty much always necessary. 2mm is a legitimate starting place. It can be adjusted in 1mm increments. Anything more than 7mm may cause the plastic melt zone to retract into the cooling zone and cause a jam. It kind of depends on the length of your bowden tube though.
