Results 1 to 10 of 10
10-27-2015, 11:56 AM #9
sorry but that's just nonsense. Abs prints are just as strong but much cleaner and sharper with fan.
One thing you can do is make a 5mm cylinder the same height as your print. uses way less plastic than a purge wall - but has same effect.
For longer cooling times use two at opposite corners of your build plate.
New member with print issue
