Thread: New Pro Owner Help
10-23-2015, 10:41 AM #1
- Oct 2015
New Pro Owner Help
HI folks, iv just got my first Printer, went with the flash force Creator Pro, got it setup and working and am playing today with the small Marvin figurine from 3d hubs,
I am after some set advice, initial print was poor, iv reduce speed and its better but its got sagging around the, front, ears and lower back ares, also i can see distinct colour diferance between the top half and bottom half of the model, goes from dark at the bottom to lighter at the top with the big shift in the middle.
I printed it in Replicator G with the setting in the picture,
id appreciate any advice
thanks
10-23-2015, 04:39 PM #2
- Feb 2015
- 91
Creator Pro is a Replicator 1 Dual clone, not rep2.
BTW replicatorg is abandonware
The sagging is on the overhang. If this is ABS, it can be tricky to get it to stiffen quickly enough. You can get some improvement by printing two some distance apart on the bed. You can try printing at a cooler temp, but you may introduce other problems.
