Results 1 to 10 of 11
Thread: Hotend for Stratasys Dimension
10-17-2015, 01:05 PM #1
- Oct 2015
Hi, I need a Hot End for a Stratasys Dimension. Has anybody an idea were I can order one, exept at Stratasys? Also used parts are welcome.
Thanks in advanced!
regards
jnskst
10-17-2015, 01:58 PM #2
- Burnley, UK
- 1,662
They are rare as chickens teeth. PM Treak, he may be able to help.
10-17-2015, 03:17 PM #3
Where can we purchase "Chickens Teeth" ??
I want some for my Special Tooth Collection !
Or should I just 3D-print Some instead ??
10-17-2015, 03:42 PM #4
- Burnley, UK
- 1,662
Hmm, hasrder to 3d print that you imagine, where will you get the STL file?
10-17-2015, 04:17 PM #5
10-20-2015, 02:42 AM #6
10-20-2015, 02:48 AM #7
- Burnley, UK
- 1,662
Send a private message (PM) to Treak (use the search facility to find him, he is a member on here). He does a lot with breaking / mending Stratasys printers and he may be able to point you in the right direction.
Be prepared to pay lots for it as they are very rare and you will not find a new one except from Stratasys.
It is possible to make a new one, they are just normal engineering, nothing magic in there.
10-20-2015, 04:43 AM #8
10-20-2015, 06:04 AM #9
- Oct 2015
Hey guys,
thanks for the replies. Thats what I thought. I have already a copy in 3d cad. I struggle only a little bit with the tubes. It is not easy to get them here in Germany with this dimensions.
10-20-2015, 06:14 AM #10
- Burnley, UK
- 1,662
There is a guy that sells 30cm lengths of stainless tubing on ebay. The problem is that it is diabolical to bend. I ended up doing a similar thing with brass tubing that is available from model shops and fitted stainless nozzles that you can buy for small air brushes.
http://www.ebay.co.uk/sch/sis.html?_...p2047675.m4099
http://www.ebay.co.uk/itm/5pcs-Stain...:X:AAQ:GB:1123
