Results 1 to 10 of 15
10-12-2015, 12:10 PM #2
- Oct 2015
Thanks for your great suggestions!
1- the coil target temperature and IR lamps target temperature should be saved when closing the software so we don't have to re-enter them next time
Good Idea, put it on feature requirements of 1.0.28
2- same for laser scanning speed. I forgot to change it from default 250 and my print was melting. YOu should maybe change the default from 250 to 400 if you cannot save our last parameter.
Already implemented for 1.0.28 - both now with saving and default set to 350 (your previously entered speed value gets automatically communicated to the printer each time a print is started, if you forgot to set the speed manually by pushing the button).
3- can you add an APPLY Powder button to the screen where we monitor temperatures ? this way we don't have to change screen when applying the first 5 layers before a print session
Already implemented for 1.0.28: There's a new paramter, number of empty layers before print (so that the applying of the first 5 layers gets done automatically).
Still a good idea to add the button to the "4. print" pane, I put it on the feature requirements list.
4- is there an easy way for you to add the possibility of changing lamp power factors WHILE printing ? at present we can only change them in config file and have to re-start printer each time. Would be great to do this on the fly when calibrating the printer.
That is a good input but out of scope for now since it involves deeper changes to the printer firmware (put it on the feature request list).
5- i don't see any STOP Printing button , is there one ? How can we stop the printer before the end of the printing job ?
There actually is a STOP button in 1.0.27, on the print pane, left of the progress bar. I took note that it's not visible enough. But in 1.0.28 the STOP button will temporarily be removed since there's a firmware bug resulting in being unable to start a new print after pressing STOP (defeating the STOP button's purpose).
6- would be nice to have a PAUSE printing button also.
The PAUSE button is right besides the STOP button. Fix in 1.0.28: Pressing PAUSE again will resume the print
7- YOu should display the number of the current layer being printed. The % is not enough
Already implemented for 1.0.28.
8- Is it a big work to compile your software for 32 bits windows ? At present i have only one 64 bit computer so it's difficult to have it tied up when printing. I have 2 other older laptops but all 32 bits.
There will be a 32 bit support soon, but for now we focus on the 64 bit version. Arguably we could have gone 32 bit only, but the 3D stuff and slicing benefit tremendously from 64 bit. I could post here once we have an early 32 bit version...
9- Possibility to display how much powder there is left in the powder chamber
We know about the necessity of that one, but that's something that would require work on the firmware and is not possible immediately.
Now about the printer firmware, we have a huge rework coming up. We've taken all feedback we've got so far (if someone reads this and has more, please post ) and tons of improvements from our side (much more sophisticated temperature control, better motor motions, complete new low-level and reliable USB communication and so one). It'll be done in about 4 weeks (We've got less frequent firmware updates compared to desktop software since deployment is an hassle).
1.0.28 update will be pushed by the end of the week btw.
Thanks again for your input. Cheers!
Dominik form SintratecLast edited by Dominik; 10-13-2015 at 09:17 AM.
