10-12-2015, 02:09 AM #2
Out of the box settings... there's your problem. You really need to sit with your printer and get to know it inside and out as it will need to be fine-tuned. The out-of-the-box settings will not give you great results.
A few points:
- You must calibrate your extruder!! Must! You don't say what printer you have but here's a good place to start.
- Decrease print speed to 50mm/s.
- A bed temp of 110 degrees is too high for ABS. Drop it to 95.
- Increase your extruder temp to 230 for now. You can fine tune that later.
Do all of that first. And report back.
