Results 11 to 16 of 16
10-04-2015, 08:43 PM #11
- Sep 2015
- Liverpool
- 25
and here's your second one
Ok still some way to go yet before it's working, as has been mentioned controlling the extra axis could be a little tricky, would be cool if someone figures out how to use a brushless gimbal board with Ramps or other controller.
Of course I need a rotating unit for the 4th axis, and need to rotate the Y axis 90 degrees, but I'm waiting on a few parts before I can complete the Y and second Z axisLast edited by MechaBits; 10-04-2015 at 08:53 PM.
10-05-2015, 01:21 AM #12
- Burnley, UK
- 1,662
Why do you want to control a brushless gimbal board?
10-05-2015, 05:13 AM #13
well you know what those bloody ginbals are like when you give them brushes !
10-05-2015, 08:08 AM #14
- Sep 2015
- Liverpool
- 25
Because I lost both my thumbs in a drone attack.
I realize it's probably not the way to do it, but was working on the gimbal before the printer, and the thought of software contol of the pan & tilt came up. 2axis boards are very cheap, though not much cheaper than a Ramps, but its a self contained unit. Some 32bit,
So if it was possible it would have to sync somehow, but just for controlling position of pan & tilt not for acting like a gimbal, but steppers probably have an easier time holding position.
but i dont have a degree in robotics, so a little more experimentation needed. Would like to get familiar with Mach 5 and some alternate stepper drivers.Last edited by MechaBits; 10-05-2015 at 11:10 AM.
10-10-2015, 07:06 PM #15
I wonder how it would work with materials that are not stiff and that could be affected by gravity, (droop/sag) or wobble due to thin design. Making sure the print sticks to the bed would be challenging as well I'm sure.
Very cool indeed, not withstanding challenges.
6 axis printer. Sweet!
https://www.youtube.com/watch?v=qGyiXFGvkqELast edited by Christopher Mann; 10-10-2015 at 07:13 PM.
10-11-2015, 02:15 AM #16
- Burnley, UK
- 1,662
That's the most over engineered delta printer I have ever seen.
