Thread: 3Dison H700 x Delta Wasp 4070
10-09-2015, 08:34 AM #1
- Oct 2015
Hi guys,
I want to buy a big build printer and found these two models with similar price, build and quality.
Which one do you recommend?
Why one is better than the other?
Thank you!
10-09-2015, 09:32 AM #2
If I were in the market for a large format printer I would go with the Robobeast
Of the two you listed, I dunno to be honest. The 3Dison, probably. Only because I'm no fan of delta printers. But the 3Dison looks to be using proprietry filament. And a max print speed of 1000mm/s?! Yeah... riiiiight... Also try and print a 680mm high vase on a spring loaded cantilevered platform. Issues will be had...
10-09-2015, 12:22 PM #3
- Oct 2015
Thank you very much for the quick reply Sebastian.
Why don't you like delta printers?
Sorry if I don't understand some terms that you use, I'm just a padawan in the 3D printer field.
Why do you believe that is so hard to reach a printing speed of 1000mm/s? I also didn't find any other model so fast.
What is a spring loaded cantilevered platform? Can you send me a picture?
